Is an alignment REALLY needed after a lowering spring install?
On the left is the passenger side front tire, on the right is the passenger side rear tire. These are BFG KDW tires, in case you're wondering. Both tires were purchased on the same day. At 10K miles, I rotated the tires front to back. I'd estimate there is about 20K miles on these tires. You can clearly see that the inside tread is VERY worn compared to the rest of the tire. I installed Hotchkis springs and didn't get an alignment done until right before I pulled these off to get new rims and tires.
I'd say an alignment is necessary. It's not that expensive.
-Mike
