LT1 ABS modulator removal
Old Feb 11, 2006 | 09:39 AM
SprayedLT1's Avatar
Default LT1 ABS modulator removal
What all is there to taking this all out? I have been planning to remove it and add a line lock and proportioning valve, and I just discovered the SJM delete kit and line lock. I'll probably get one of those kits.
...but what all do I have to do to get the modulator and bracket out of there?
Old Feb 11, 2006 | 07:29 PM
SJM Manufacturing Inc's Avatar
The complete kit comes complete with everything that you need. The actual modulator and bracket comes out by a few bolts. The LT1 components are VERY heavy. I can walk you through any portion of an install once you have the kit in hand if you don't understand any of the pictures or directions.
Wait until you see how much space you're cleaning up there after you remove it all.
Steve
Old Feb 12, 2006 | 07:33 AM
SprayedLT1's Avatar
Thanks Steve. I'll look you up if I have any problems.
