Squeaking from Rear
Old Feb 11, 2006 | 05:07 PM
grimm2420's Avatar
Default Squeaking from Rear
Theres a loud squeaking that is coming from the rear whenever i drive over bumps. Initially i thought that maybe the rubber isolators weren't in, and i was going to pull the springs out and put some heater hose around them ... but after i pulled the springs out i found that the rubber isolators were in there. Do i need to put the heater hose around the bottom portion of the spring? What else causes that kind of loud squeaking?
Old Feb 11, 2006 | 06:09 PM
grimm2420's Avatar
Well it's not the lower portion of the spring ... i put heater hose around that end and it still squeaks pretty loud. I can hear it every time i jack the car up and down, i just can't pinpoint it.
Old Feb 11, 2006 | 07:15 PM
CW00BlackTA's Avatar
If you have aftermarket parts, make sure all of the joints are well lubricated. That's a common cause of squeaks.
Old Feb 11, 2006 | 09:43 PM
HAWKVERT's Avatar
Lightbulb
You might check your rear swaybar linkend bushings and make sure they have grease on them.
Old Feb 11, 2006 | 09:50 PM
grimm2420's Avatar
you know what... i had my brother jack up the car while i was looking under from the rear and i can tell the squeaking is coming from the sway bar where the U bolts connect it to the axle, not the bushings. am i supposed to lube this part as well as the bushings? if i don't make sense i could take a pic of the area the noise is coming from
