Torque arm bushing change
Old Feb 15, 2006 | 10:45 AM
THE CHOP SHOP's Avatar
Default Torque arm bushing change
My torque arm bushing is shot and plan on replacing it with the energy suspension one. I did a search but did not find much on any tips on doing it. So if anyone can give me some tips on the replacement i would appreciate it.
Old Feb 15, 2006 | 11:02 AM
MeentSS02's Avatar
Kleeborp the Moderator™
You'll have to drop the tranny crossmember to get to it...other than that, pretty straight forward. There are three bolts that hold the clamshell in place...two of them are through bolts (on the bottom, and one is actually a part of the clamshell itself that only comes out when you take the clamshell off), and the top bolt goes into a blind hole, and is the biggest bitch to get to due it being really hard to get your hand in there. The top bolt you'll be cussing at until you are blue in the face.
Old Feb 15, 2006 | 12:13 PM
bshell's Avatar
I replaced mine last weekend. Just be patient with that top bolt. Also don't forget to support the rear end before you remove the TA.
