adjusted camber?
Old Feb 20, 2006 | 11:17 PM
camaroguy_02's Avatar
Default adjusted camber?
has anyone thought of adjusting the front cambers on a camaro for better handling, or even just for looks?
new at the modding thing, so i dont know if this is even do-able for camaros. i just liked the look of the slanted tires.
Old Feb 21, 2006 | 08:40 AM
Strokinit383's Avatar
Spec on the old IROC's was about -.5. That might be a good starting point for the street.
Old Feb 22, 2006 | 09:37 AM
SS SLP2's Avatar
CAMBER adjusts on lower control arm the front bolt adjusts camber the rear one adjust caster, YOU must have realign at once you adjust because the adjusting will CHANGE TOE a great amount -which is the most wearing factor- you may change camber quit a bit - depends on car , I would not go past -1.00, but then I do not like any beyound +
come to my site to understand alignment
go 3-4 pages deep, at opening page click on the EMBLEM in center of page then follow prompts , good luck ,Johnny
http://www.kickme.to/jgruggles
