How many spring compressors needed for install?
So.... will two spring compressors help?
Installing: Eibach Springs & Revalved Bilstein HDs
Thanks Sam,
You were about right on the shipping time too, about 3 weeks at the beginning of nascar season probably isn't too bad at all.
A heads up be sure you line up the top part, where the nut goes, before you tighten them back up. In other words make sure you have the top part where the bolts go in the right place in relation to the bottom. Its hard to explain, but once you get there just make sure you double check before you tighten up the new nut and uncompress the spring.
Trust me you dont want to be doing double work.
Oh and be sure to clean the threads and the nut on the upper A arms shaft. A lil lube wouldnt hurt either. I'm talkin bout the one that holds the steering knuckle. Reason is that shaft can spin if it has to much resistance. So you will never be able to fully tighten it back up cuz it will just spin and spin.
Getting the shock to line up to the bottom holes might be trouble I say might cuz the stock ones didnt but my Konis did. So be sure you have someone align it for you until you can get the bolts in, this sounds easier said than done.
Thats all I can think of for now.
That should be the page for the fronts. Please read carefully, and please use extra caution when removing and replacing the spring. 10 years ago, a friend of mine was doing this on another vehicle, didn't heed my warning, then there was an injury from a projectile flying off then ricocheting after a careless move to decompress. Just be patient and prudent, and things should run smoothly.
You should only have to use the spring compressors for the front set only, since the rears can simply pop out when the axle drops low enough. Here's the instructions for the rears.
http://www.ls1howto.com/index.php?article=8&printable=y
