What exactly does the STB do?
Let the real suspension parts do their work, such as a proper shock/spring/stabiliser bar combination, and not some mere tubular parts that have contrived advertisements and testimonies to what they can supposedly improve. Again, these parts have their place, just not all of what the consensus purports them to do.
I was one of those who started with SFC's and a STB because, "It's an absolute must and should be done ASAP!" Yeah, I thought my SOTP was detecting a difference, however, track numbers don't lie. After installing those items alone, it was still the inconsistent hit or miss times, and handling was still not so predictable. AFA the NVH, no change from the previous times without SFC's and STB. I even upgraded to a 3-point STB, still no change from the 2 point STB.
Then came a combination of newer parts that were similar to the 1LE setup (looked at what was included in the 2001-2002 1LE and ordered the items separately). After installing the parts, and configuring the shocks, a vast improvement was not only felt by SOTP, but also my track times were much more consistent. AFA the STB, I removed that item, and guess what? No change in SOTP with the Koni DA's and the 32/19 stabiliser bar combination. Why, because I let the a set of quality shocks perform like they supposed to in the first place. Even then I still messed around with installing, uninstalling, and reinstalling several times. Also, no change in distance between the shock towers, even while driving (used an instrument that mounted like a STB, but was shaped like a hood shock with probes to measure the distance changes and tower angles during cornering. No changes!).
Even between the stock setup, the "1LE" setup, and what I have now, I have reinstalled and uninstalled all of the SFC's and STB's on not only mine, but also my colleague's test subject (2000 T/A test vehicle "stripped") for several times. Quite a lot to do, but when you can test not only one make and one design at one time, but at least two or more makes of at least two different designs at several intervals, then the results can be much more credible.
Now, what I am getting at is what many seem to "notice" is totally seperate from what may actually is being measured. That's what seperates simplified placebo effects from critical testing. As many of the frrax people are concerned they do this more often, since they are critical to actually discovering whether an item works they way it's advertised or not. Plain and simple.
Contrary to what you state about my answer being not so clear cut, your last statement needs more than just judging others so this thread can be objective.
Here's two examples of what I'm talking about:
https://ls1tech.com/forums/showpost....3&postcount=29
https://ls1tech.com/forums/showpost....09&postcount=7
Yes, these two examples don't quite mention STB, however they mention the fact that they do concentrate on those items that are of great importance to the 4th Gen F-body's handling (and braking to some extent). They both had to work with several combinations, while attempting to retain certain controls and constants. That's testing that is much more substantial to what is trying to be gained. Anyone who reads my post as it is should easily comprehend what I am explaining.
Here's another example I'd like to mention, several Camaros competing against each other on a tight AX cone course.
http://www.1le.net/docs/tittermary.jpg
For those who are predominantly "daily drivers" and have never AXed, this is much harder than what most will do in daily driving, and guess what? The 1LE came out on top, and from the factory the 1LE has no STB. The only thing that this car had which was not stock were the tyres. The LG Camaro came in a close 2nd, and most likely had an STB as that was part of his past advertised "ZR28" package. The body roll that was described for the 1LE was really down to the spring rate and stabiliser bar combo, which allows slighty more body roll than the LG ZR28.
If there was way too much tower flex during manoeuvering, then I would hope that they would mention how the hood flexed. They don't, plus the owner mentioned that they didn't have to worry about tearing it up because he doubted they could drive the vehicle harder than he did.
Another thing to mention is how the 1LE was actually the lightest of all of the vehicles, yet the driver's couldn't differentiate that from the others by the feel of handling. By noting that and looking at other factors, they have eliminated much of any possible placebo effect.
Another factor that can change feel of handling would be the front end suspension alignment. A few degrees difference in caster, camber, and/or toe can have dramatic effects on ease of steering and/or optimal cornering grip.
I have done this "test" on eight (yes, 8 of them) of my friends' 4th gen verts. I basically attached my STB's on their's thinking that they had much worse problems, and they supposedly didn't feel a thing. I drove around in their vehicles and still didn't feel a thing. They let me AX them, didn't notice any improvement in times with or without. A few elected to upgrade their shocks (bilstein HD's with stock springs) and those who did felt a slight improvement. Reattached the STB, did the exact same tests as previous (weather luckily permitted), no noticable SOTP changes with or without STB. I had to completely repeat this like crazy in order to make sure that I surely wasn't feeling a thing. While there is a difference in design with the centre of converts vs. hardtops/t-tops, the front's are exactly the same from the factory.
Now as far as the designs of the STB's I own (no longer installed) and have seen advertised, there aren't any that will attach to all four attachment points on the shock towers. I would like to think that if a manufacturer was to go to the trouble of making an STB for the 4th Gen (or any vehicle for the matter), wouldn't they go a little further to manufacture ones that attach to all four shock tower bolts?
If changing your shocks and springs greatly reduces cowl shake, great. A problem has been greatly improved.
Or...
If putting on a STB also has a similar effect, great. The STB will not affect handling, just feel. Using it for NVH is in fact a valid use.
The shocks and springs helped by making existing parts work better. The STB did it by adding stiffness. Both are good, so do both. Don't want a STB? No one will mind.
EDIT: To those with concerns outside of purchasing/selling an item or to those who I have no familiarity, and those who aren't moderators who have political objections with my postings, DON'T PM me.
Both do something on their own, but the two can't be added together? Nonsense.
Each persons acceptance is their business. You are now attempting to antogonise an argument against me. I will post what I find and reasearch, that's it. It's each member's buisness what they post. Anybody can take it or leave it. I don't need last words, fame or fortune. It's that simple.
haha...very funny guys,
