sway bars - alignment
Old Mar 6, 2006 | 11:50 AM
shaunleger's Avatar
Default sway bars - alignment
I don't know too much about alignment, so I hope this isn't a stupid question. Is there any way adding aftermarket sway bars could change your alignment?
Old Mar 6, 2006 | 11:58 AM
jyeager's Avatar
Not really. If the bar was twisted it could preload one side more than the other resulting in a left/right disparity in suspension compression...and this affects camber somewhat.
So unless the sway bar is bent, or the end-links adjusted wrong..no. Even then, this would only make a small difference.
