Changing shocks and springs...
Old Mar 11, 2006 | 12:34 PM
2001 White Ws6's Avatar
Default Changing shocks and springs...
Got the pass. side shock and spring off but i can't get the top nut off the spring perch. I can't even budge the ****** without the shaft spinning.
How do i cut this bitch off...i have a dremel at my use but i can't even budge the nut so what would you do to cut this **** off.
HELP!!
Old Mar 11, 2006 | 01:22 PM
02SS#406's Avatar
Are you getting rid of the Hotchkis springs? PM me if you are. I'm in DFW also, and may be interested.
Old Mar 11, 2006 | 01:36 PM
musclehead's Avatar
You need to use an allen wrench on the top to hold the shaft in place, then try turning the nut with an open end wrench. It will be a slow process but should work, also hit the nut with some liquid wrench.
Old Mar 11, 2006 | 03:02 PM
I'm taking out the G2 super springs and the hotchkis sprigns are going in with bilstein revalves.
Old Mar 11, 2006 | 03:03 PM
It's the stock shock shaft so there's no place to use an allen wrench. It's a flattened tip but vise grips nor a crescent wrench will keep it from spinning.
