eibach question
Old Mar 13, 2006 | 05:03 PM
rjkZ28's Avatar
Default eibach question
is there a difference between the prokit for a 97lt1 camaro, and a 02 ls1 camaro?
Old Mar 13, 2006 | 05:13 PM
rjkZ28's Avatar
the reason why im asking is b/c i set of eibach prokit for a freind who had a 97 camaro, so i was wondering if they are ok for my car? im going to be buying revalved bilsteins in the next day or 2.
Old Mar 13, 2006 | 05:54 PM
rjkZ28's Avatar
i take it since there is no response that there is no difference?
Old Mar 13, 2006 | 06:04 PM
May Spin's Avatar
Front 377-600lb
Rear 94-160lb
98-02
Front 400lb
Rear 80-137lb
If you are getting revalves you'll be talking to Sam... He'll tell you what's best and will valve the HD's to match that specific spring rate. LT1 cars were heavier due to their iron block, that's why their spring rates are more. They will certainly ride stiffer on a 98-02 car.
Old Mar 14, 2006 | 12:31 AM
rjkZ28's Avatar
ok thanks for the info i didnt know they would ride ruff, that would explain it. also to i figured since the lt1s were heavier that would explain why my fronts sit a little higher then normal. maybe i should get the right springs then.
Old Mar 14, 2006 | 10:44 AM
rjkZ28's Avatar
alright im gonna order the shocks today i need to know if i can leave the lt1 sprins or should i get the right ones?
Old Mar 14, 2006 | 10:51 AM
Sam Strano's Avatar
LS1TECH Sponsor
Dude, you have to call me anyway.... I don't do Revalves by e-mail.
I'll answer all your questions (and take care of the SFC's you want as well).
__________________
