What pinion angle?
If you've got a strong torque arm with a urethane mount then you might be able to run less pinion angle. Your LCAs could impact this. With the relocation brackets you will gain antisquat and this might cause the rear to lift under load. That might change your pinion angle itself.
If you have no wheel hop, then there is no concern for your 12 bolt. It's just that a bad pinion angle can often cause wheel hop. Beyond that, a bad pinion angle can cause an annoying vibration at cruise.
