brake upgrade
Old Mar 16, 2006 | 12:34 AM
vitamanz's Avatar
Default brake upgrade
Iwill be doing a brake c5 upgrade soon was wondering if anyone uses silicone brk fluid or not nec. also I have bremos drilled/slotted rotors any one using these?
Old Mar 16, 2006 | 08:20 AM
trackbird's Avatar
Stay away from the silicone based fluids. They are compressable and give a spongy/soft pedal. Stick to Dot 3, 4 or 5.1.
Old Mar 16, 2006 | 09:58 AM
Dom's Avatar
Dom
What fluids are recommended?
Old Mar 16, 2006 | 10:50 AM
trackbird's Avatar
I use ATE Superblue and ATE TYP 200 (same fluid, one is gold one is blue so you can tell when you get fresh fluid, you just alternate between them each time you bleed the system). You can get it from most of the sponsors here it seems and it's great stuff.
Or, Valvoline Syn power is not bad stuff.
Old Mar 16, 2006 | 11:09 AM
1QUIKWS6's Avatar
Active Streak: 30 Days
Syn Power for ABS is what I use...
