Brake kit options
Old Mar 26, 2006 | 12:43 PM
C_Rules's Avatar
Default Brake kit options
Im getting bigger brakes on my car real soon now that im getting my heads and cam on monday. My LT1 brakes are crap so im looking for an upgrade. Im not an auto x or rr guy so the brakes arent going to be getting beat up that hard. The cars a daily driver and I need some brakes that have real good stoping power. Should i get a willwood, ssbc, or baer type break kit or should i go for a c5 kit? How many pistons in the caliper should i go with? Any suggestions will be appreciated since they're so many options and different options out there and i dont want to rip myself off.
Old Mar 27, 2006 | 11:19 AM
tekprodave's Avatar
I'm in a similar situation. I've heard you can use LS1 brakes but I'm unsure of all the parts that are necessary. Spindles, lines, rotors, calipers, What do we needs? Is there anyone that makes a complete kit that includes everything?
Old Mar 29, 2006 | 06:07 PM
C_Rules's Avatar
ttt...
Old Mar 29, 2006 | 07:36 PM
Racafella13's Avatar
Im wondering the same. i need new rear calipers would it be better to get ls1 calipers and do they just bolt up and do they use the same rotors?
Old Mar 30, 2006 | 11:49 AM
tekprodave's Avatar
I've heard the rears are funtionally the same so there is no advantage to upgrade the rears to LS1 components.
Old Mar 30, 2006 | 01:30 PM
trackbird's Avatar
The LS1 rears are larger than the LT1 rears. It is an upgrade (if it's needed or not is another discussion, but it is an upgrade). The caliper, rotor, backing plate, brake shoes (for the LS1 parking brake) and brake cables (and hoses) are needed. If you do some searching there are a few writeups on making the rear swap out on the web.
