Front hub removal
Old Apr 9, 2006 | 05:07 PM
JRcamaroZ28's Avatar
Default Front hub removal
is there a special way to seperate the hub from the steering knuckle? i have the 4 bolts out but its on there pretty good...i didnt want to force it so that nothing breaks w/ the sensor..thanks in advance for any help
JR
Old Apr 9, 2006 | 08:12 PM
UMI Performance's Avatar
Its just a tight fit, almost a press fit but it comes off. Keep trying, it will break loose.
Old Apr 10, 2006 | 05:35 AM
thanks alot
JR
Old Apr 10, 2006 | 07:59 AM
steve-d's Avatar
This technique will result in destroying a bolt, but helps when the hub is rusted / frozen to the spindle.
Insert a bolt back in a few threads. Use it to pound away and push the hub out by hitting the bolt with a hammer.
Hit a few times at each corner until it starts to come out.
Replace with a 10 x 1.5 x however long the bolt is.
Replace with the grade 10 metric hardness.
