What angle on pinion???
Old Apr 10, 2006 | 12:44 PM
novi2000's Avatar
Default What angle on pinion???
whats the best angle on an adjustable tourque arm for the best traction street/strip?? thanks guys
Old Apr 10, 2006 | 03:11 PM
blown 346's Avatar
I think it is negative 2, if I remember right.
Old Apr 10, 2006 | 04:04 PM
OldeSkool's Avatar
its really more a question of durability/wear than traction. The only reason a negative angle is desired is because you are always going to have some flex under launch. Some setups flex more than others and may need more negative pinion angle.
So on a hard launch, the pinion flexes up a little. By setting it negative, this hard launch pulls the pinion up to around 0 as opposed to several degrees positive.
This hard launch is the most stress the pinion is ever under, so by having it close to 0 degrees when things are under stress, you are less likely to break something.
The flip side is, you will be off 0 (negative) the rest of the time, which causes some wear. A degree or two wont hurt anything too much and shouldnt cause too much increase in vibration, but ask yourself if how often you do hard launches and if they are hard enough to merit a negative angle the rest of the time you are driving.
Old Jul 4, 2006 | 08:38 AM
damon_Z's Avatar
Very informative.
When you say causes some wear, where would the wear be? Also, will a negative pinion angle negatively affect handling? Thanks in advance for the info.
Old Jul 4, 2006 | 12:59 PM
OldeSkool's Avatar
The wear will be on the pinion bearings. If they wear enough, i suppose it might start wearing the pinion gear.
A negative pinion angle- within reason -won't affect handling.
