quick brake question
Old Apr 13, 2006 | 01:06 PM
dudemandanman's Avatar
Default quick brake question
i just had my brake caliper brackets powder coated and i'm about to reinstall them. i just want to know what to use for the caliper pins. should i just use that gray anti seize stuff, or the clear silicone stuff?? any suggestions?
i heard that the silicone stuff can eat away at those rubber gromet things.
so any advice is greatly apperciated.
thanks!!
Old Apr 13, 2006 | 01:27 PM
trackbird's Avatar
Go to your local parts store and ask for "Disk Brake Caliper Grease/Lube". They will usually give you a little packet of lube for those pins. Permatex also makes a good caliper grease (it's synthetic as are most of them). Use real caliper grease, nothing else will handle the heat properly.
Old Apr 13, 2006 | 03:30 PM
cool, thanks.
