How the hell do I get this nut off!!
Use a dremel tool with a cutoff wheel to cut through the nut as much as you can. You'll be cutting at like a 45 degree angle and that's ok. Just cut through as much as you can without going through and f*cking up the bolt threads. Make two cuts like this 180 degrees opposite eachother on the nut to weaken it. Grab a chisel (or your least favorite large screwdriver) and wack it off. If you cut enough, it won't take much since the nut is so rusted.
This worked on both of my shocks. You'll obviously need to go to the hardware store for some new nuts. Even if you got the nuts to start coming loose, they would bind up on all of that rust and snap the bolt so you need to cut the nuts off and then clean up the bolts with a wire brush or wheel.
it goes over the oval shaped part of the shaft at the end, where the nut is
but so far with all my experience, the oval shaped part where the tool holds just breaks off.
good luck
I then rented the GM suspension kit from AutoZone and broke the damn square part off, just as 1999Z28 noted.
So I took my dremel and cut the whole damn bolt off. I bought a cheap set of shocks that should last till this summer when I can put a good set of KYB's on there The shocks I bought have a lifetime warranty, so if they go bad I'll just replace em.NOW I've got another problem!!! I got the passenger side done and installed. When I cut the bolt off the drivers side, I can't get the strut mount to come loose!! Hell, the bolts off!! Why won't the strut mount come off!! I've got it soaking with PB Blaster overnight....maybe I can get it in the morning.
I got to say that this was WAY...WAY...worse then changing the plugs. I'd take the plugs any day over this!
Thanks again for all the help, and if I could get some ideas for this latest dilemma I'd apprectiate it.
Jason
Then I began backing the nut off using liberal amounts of WD40.
I would turn the nut about 1-2 turns and then retighten a turn, spraty with WD40.
The reason is I couldn't get all the corrosion out of the threads using the wire wheel. As the nut backed off, the threades of the nut would scrape the corrosion off and get in the threads and bind the nut onto the threads once again.
So, tighten the nut a little, reapply WD40 to not only lubricate, but to wash away the loose corrosion, and loosen another turn or 2 ... until it begins binding.
This method has yet to fail me.
Now it's time to kick back and enjoy a few brewskis!
Thanks for all the help it was much, much appreciated!
Yeah, it seems like there is always something that goes wrong, but this time it was one thing after another!
I'm glad the whole thing is done! I got the look that I was after, so in the long run, it was all worth it. Plus, now I have a third vehicle, so if I only feel like tightening one bolt on the car in an evening, I can do that.
Congrats on the spring swap. Sorry it went so badly for you, but at least it's done. You did put some anti-sieze on the new bolt, right?
-Mike
-Mike
What worked for me was an impact wrench. Few tries with that and it got it off. I was so freaking happy. lol
