torque arm...
Old Apr 16, 2006 | 09:37 AM
sandro arellano's Avatar
Default torque arm...
well i wanted to know if anyone has a good fix for the dreaded torque arm bolts loosening up. i tighten and retighten over and over again with the same outcome. i have used loctite with the same end result after a few hundred miles. anyone have a good fix for this?
thanks in advance
Old Apr 16, 2006 | 10:12 AM
Duffster's Avatar
replace them with the ones that have that nylon washer in them. . .
or. . .tach/spot weld a dot to hold them once torqued. . .
