Rubbing issues
Old Apr 18, 2006 | 02:33 AM
FrozenMonkey's Avatar
Default Rubbing issues
Ok, this is kinda a dual question, don't really know what one it would fit in so I threw it in here instead of wheels and tires...
I currently have a set of 18" Z06 replicas with 275/40's all around. Also have Eibach Pro-kit springs and stock de-carbon shocks. The problem is that while under heavy turning or if I go over a bump my wheels will rub against the inside fender walls. I bought some $5 spring spacer things and put em between the coils to see if that would fix the problem but just gave me a little more room before it will rub. Now, my questions are:
1. Yes, I'm upgrading my shocks, but will getting new shocks such as Bilstien HD or KYB AGX Adjustable's solve the problem?
2. I'm getting new tires soon/near the same time as shocks, should I get the same tire size or will I run into the same problem that I have now? If so, what size should I get? 265/40? 275/35? I don't want to get any lower profile tire than 35, as the ride comfort level goes to **** and it looks just plain doofy on these cars.
Any insight on this would be very helpful, as this tire rubbing is causing unnessacary tire wear and sucks while trying to drive...spirited.
Old Apr 18, 2006 | 05:49 PM
Another thing I was thinking is would a adjustable BMR panhard bar fix the problem?
Bump up for the evening crew...
Old Apr 18, 2006 | 06:05 PM
Cal's Avatar
Cal
I have one word for you: BFH . . . no I guess that's three words! Adjustable PHB and stiff shocks will help, but the BFH and some IROC-Z wheel spacers are the answer. Hey, if I can get 335's on 12 inch wide wheels to clear, you shouldn't have a problem with 275's!
Old Apr 18, 2006 | 06:21 PM
Whats the BFH you refer to? I was thinkin some wheel spacers while researching this further. I don't really know crap about suspension stuff (obviously)...could ya give some links or ideas about what spacers would be best if I did that route?
Old Apr 18, 2006 | 06:35 PM
Cal's Avatar
Cal
The IROC-Z spacers are about 3/16" and available from your local GM parts counter.
BFH = Big F'in Hammer. Just pound down the high places that show rub marks, spray paint and repeat until no rubbing. But it will need to be a really big BFH; not a little carpenters hammer. What non-car people call a sledge hammer. I use a torsion bar off a 3/4 ton Chevy truck in leu of the BFH.
A lot of vendors offer APHB's, just don't get one with the adjustment in the middle of the bar.
Old Apr 18, 2006 | 07:26 PM
Arent the inside fenders plastic? I know that just a small area is rubbing and beating the **** out of it would solve the problem, but...hammer + plastic = oops...right? EDIT: Nevermind I'm a retard, the rears arent plastic, just the front. rears are the ones having the most problems
And with spacers, would I need to get longer bolt studs?
Old Apr 19, 2006 | 02:45 PM
ZDOG's Avatar
rear fenders = bfh. front fenders possibly a spacer or make sure the plastic is on all the way. or maybey some heat and a little training.
