Loose suspension
Old Apr 21, 2006 | 09:08 PM
97SprChrgd383's Avatar
Default Loose suspension
Come on you suspension buffs! Ok, I'm sure there has been a thread on this, I just couldn't find it. My front end is completely re-done. I have the tubular k-member, tubular upper and lower a-arms, and qa1 single 12 way adjustable shocks and springs. I also have the qa1 rear struts and v6 springs. My car is walking really bad on the street. Every crevass pulls the car one way or the other. I have 275's in the front and 315's in the rear. My stock front end never did this. Am I missing something? What would be causing this and what could fix it?
Old Apr 21, 2006 | 09:44 PM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
Did you get it aligned? Are tires pressures to specs?
Old Apr 22, 2006 | 06:48 AM
Honda Hunter's Avatar
My 315/35/17's BFG DR's did that when I didnt have the correct air psi in them.
Old Apr 22, 2006 | 09:02 AM
It was aligned, and I didn't check the tire pressure. This happened to me once with my stock front end and it was a bad tie rod end.
Old Apr 22, 2006 | 09:28 AM
98_1LE's Avatar
What are the alignment specs?
Old Apr 22, 2006 | 11:19 AM
Not sure. I had it aligned at hibdons. I was planning on going back and getting the specs on it, or jus having them re-align it and getting the new specs.
Old Apr 22, 2006 | 07:59 PM
Ok, so I checked the tire pressure, and sure enough, the left front tire has way less air in it than the right tire. I just got the car back on the street after it sat being redone for a year. The funny thing is, all 3 of the other tires are still have the right air pressure in them. They are brand new tires, I mean, when I bought them right before the car went under the knife. Oh, well, I am gonna put air in it and see if that helps.
