Sounds like a spring vibrating??
Almost sounds like the springs are vibrating against the lower axle pad when the suspension is unloaded. Currently there is nothing to isolate the spring from the axle pad- Metal to metal.
Install isolator or hose over lower coil?
Have adjustable pan-hard rod and Metco LCA's, stock upper spring isolators.
Any ideas?
