Brake Problem !!
Old May 4, 2006 | 12:46 AM
Meen95z's Avatar
Unhappy Brake Problem !!
Alright, swapped out my old rearend in my 95t/a for a new built rearend. After installing it had a problem with getting brake fluid to the rear brakes. Was told it was ther proportion valve. So I put my abs unit and master cylinder out of my wrecked camaro in it. Brake fluid to all brakes now. I bled all the brakes and abs unit and still have no pedal. No leaks or anything. I had to bleed the front 2 calipers at the lines at the caliper not the bleeder screws cause one broke off. I need info asap if you have any. Thanks
