450 to the ground. suspension?
As far as other supporting suspension pieces it wud be good to invest in Lower Control Arms being my brother broke his on the stock 10 bolt with 425 to the wheels. I would also recommend an upgraded torque arm. (make sure you use Grade 8 nuts bolts in installation, I believe its called, or you will tear right through them)I would say this is the bear minimum requirements needed to get away with having some fun and not trashing parts. Of course later on you can do springs/shocks, K-members etc. later on to squeeze the most outta your 60'ft and power.
