Whats causing my squeaking?
Old May 11, 2006 | 08:43 PM
HotWhipT/A's Avatar
Default Whats causing my squeaking?
It's in the rear. The car has a lot of miles, so something is worn out. I've got new springs and shocks. What else could it be? LCA's? What should I look into getting replaced?
Old May 12, 2006 | 10:22 AM
Second_Infinity's Avatar
Back the car up on a set of ramps, get under there and start pulling on the suspension. You should be able to track down the squeaking. Mine squeaks when the poly bushings get "dry" or dirty, especially on the LCA's. The swaybar bushings can squeak as well.
