Does chassis mounted TA negatively affect handling?
http://www.umiperformance.com/2202.aspx
I'm wondering if this will have any negative effects on cornering and overall handling.
Hawk
Length of torque arm: When you shorten the torque arm, you get less rear wheel hop on accel and more hop on brake. When you lengthen it, you get less hop on brake and more hop on accel. unless you go with one of those fangled de-coupled torque arms that gives you the best of both worlds. Since handling, for people who are in the handling business, also means braking, torque arm length is important for these guys. But for the rest of us who just like driving fast around corners.. torque arm length probably isnt that big of a deal in braking.. and we'll benefit more from the launch benefits.
Bushing: the method for attachment is also an issue for die-hards. If you look at the way the torque arm in the picture above works.. you've got those 2 poly bushings. They do play a small role in axle behavior.. influincing how it twists and such.. really though.. i doubt this is a big deal though. But thats why you see some that have a sperical bushing there instead.
