E Brake ?
Old May 23, 2006 | 12:11 AM
2000WhiteTA's Avatar
Default E Brake ?
I have a rattle on the rear drivers side and it is really bothering me. I am trying to find out if anyone has any pictures of what the E brake should look like behind the rotors so I can see what is missing from mine or what is wrong with mine.
Thanks,
Brandon
Old May 24, 2006 | 07:55 AM
keliente's Avatar
I'll post a pic when I get home, I have photos of it from doing the rear end install.
Basically there's a black cable with a loop at the end of it, and a big spring covers the last 6" of the cable. That cable slips through a bracket on the rear end, and little prongs hold the cable in place. That loop on the end slips over the hook on the eBrake.
Not sure that would cause a rattle. Check your spare tire and make sure it is not loose - although it is on the pass side noise does travel and play tricks on the mind.
Old May 24, 2006 | 06:19 PM
I have no spare tire in the car. When the E brake has no tension on it I can get under the car and wiggle it so I no it is not tight. I am not sure what is rattling but if this isnt the problem I stilll need to fixx this because I should not be able to move it. Thanks for the help and please post the picks when you get a chance thanks.
