After alignment shake
Old May 23, 2006 | 10:39 AM
my number 1 hater's Avatar
Default After alignment shake
See (chopped front tires) old thread... I had the alignment done AGAIN,, had the tires swapped, saw tooth to the out side, but they r still on the front, should i swap them to the rear? and if that does not fix it WHATS NEXT>>>
Old May 23, 2006 | 11:09 AM
keliente's Avatar
Change the tires? If they are chopped up you are going to get a shake no matter how it is aligned. Moving them to the back would lessen the feeling some.
Old May 23, 2006 | 11:43 AM
I can put them on the back, AND burn them bad boys smooth again!!!! i will take a few pics too.. nothing better than some new burnout PICS... But i still need some help with the front end problem.
