How Much $$$$ To Install Two New
If it's the rear's definitely do it yourself. If it's the fronts, you might have problems getting the upper shock mount disassembled if it's rusty. But other than that, a basic socket set, a pickle fork (or makeshift equivalent) and a couple hours taking your time should cover it. Oh, and a big torx socket if you haven't yet switched it out for a normal bolt on the drivers side.
LS1howto.com should have all the necessary tools listed for the spring/shock swap. If you decide upon a shop, they'll probably charge you at least $250 unless you have contacts.
http://www.ls1howto.com/
or
http://www.installuniversity.com/ins...sity/index.htm
Rears shouldnt take more than 30 minutes.
Fronts shouldnt take more than a couple hours.
