Front shock question
Old May 24, 2006 | 09:03 PM
Compstall's Avatar
Default Front shock question
It's been so long since I had the front shocks out of the car I can't remember: isn't the bottom spring plate pressed on to the strut, i.e. non-removable? I bought new ones today and the new ones don't have any bottom spring plates on them. They should, shouldn't they? Wrong part?
Old May 25, 2006 | 02:44 AM
May Spin's Avatar
Your stock "spring plate" is removable. Just switch it over.
Old May 25, 2006 | 07:24 AM
99 Pewter TA's Avatar
This should help you out alot.
http://www.ls1howto.com/index.php?article=6
Old May 25, 2006 | 07:37 AM
chupr0kabra's Avatar
It's not pressed on. If you tap on it with a hammer, it will loosen up and slide down the shock body (away from the mounting tabs). When it gets to the disc at the end of the shock body, keep tapping and the disc will pop off.
-Mike
Old May 25, 2006 | 07:44 AM
Compstall's Avatar
Thanks for the info guys.
