Need help on Koni install
Old May 31, 2006 | 06:04 PM
Artic98T/A's Avatar
Default Need help on Koni install
I bought Koni 4/4 from Sam and have the rears in with stock springs and heater hose mod but the fronts are being a little more tricky. I have the struts out and took them to a shop to take the springs off and I had them install the stock springs on the koni's (lower perch) but in doing so the mounts wont line up. Is it possible to twist them so I can get the bolts in or should I just rent some spring compressors to adjust the top of the strut so everything lines up. Any help is greatly appreciated.
Old May 31, 2006 | 06:35 PM
Viper's Avatar
Try searching on frrax.com, there's plenty of posts on how-to.
Old May 31, 2006 | 09:23 PM
Powered By V8's Avatar
yes you can twist them. i had the same problem and i put some vise grips on the bottom mounts and used some elbow grease
Old May 31, 2006 | 10:27 PM
LS1vazquez's Avatar
I ran into the same problem myself. I just lined up the shock with the compressor still on them, line them up, and then marked the shock and removed the springs.
9/10 it will work out.
