correct way to weld in LCA relocation brackets?
Old Jun 1, 2006 | 07:11 PM
contraststriker's Avatar
Default correct way to weld in LCA relocation brackets?
My buddy had a friend weld in his LCA relocation brackets, but the way the guy did it, now his rear wheel is slid back towards the rear of the car considerably. Are the brackets supposed to be welded with weight on the axle so you can see approximately where the control arm will mate with its relocated, lower hole? Is there a right and wrong way to do it, or am I just making it too complicated?
Old Jun 2, 2006 | 05:37 AM
leadfoot4's Avatar
IIRC, I bought mine from Global West. They had an upper hole that lined up with the stock mounting hole. When I installed mine, I ran a bolt through the stock hole and the upper hole on the relocation bracket. I then lowered the car so a jackstand was holding the relocation bracket tightly against the stock bracket. I then welded the relocation bracket in place.
For added safety. I kept the bolt in place that goes through the upper holes.
