Suspension Help ! ! !
Old Jun 7, 2006 | 07:48 PM
96 LT-1's Avatar
Bad Seller Warning!
Default Suspension Help ! ! !
Ok guys i want to do a full suspension where do i start??? its street / strip i dont care about turning lol ill take it easy on the turns. but either way what parts do i get first? i heard i should take out my front sway bar....? is this true??? SFC are supposed to be first from what i hear?
Old Jun 7, 2006 | 10:31 PM
CW00BlackTA's Avatar
You need to provide more info. Looks like a drag/cruise car. How much power?
Old Jun 7, 2006 | 10:37 PM
96 LT-1's Avatar
Bad Seller Warning!
just basically stock right now.
Old Jun 8, 2006 | 02:10 AM
UAZ28SS's Avatar
Removing the front sway bar is for track purposes, which it sounds like you have in mind based on the "i dont care about turning lol ill take it easy on the turns." statement. SFCs would be a good start for you to stiffen up the chassis, LCAs, reloc. brackets for them, panhard bar, springs/drag shocks, STB, and tubular k-member if you're really hardcore....lol
Old Jun 8, 2006 | 06:15 AM
96 LT-1's Avatar
Bad Seller Warning!
whats the point of buying an aftermarket front sway bar then?
Old Jun 8, 2006 | 12:54 PM
coolformula's Avatar
If you don't care about handling.
At the track you can take off or disccount the front sway bar.
I would get some drag shocks...maybe air bags....
Old Jun 8, 2006 | 02:56 PM
DONAIMIAN's Avatar
Less post more search button. Its obvious you have no clue what you want.
