torque arm or not?
Old Jun 20, 2006 | 09:00 PM
a-low's Avatar
Default torque arm or not?
hey tech peeps,gotta quick question. Do ls1's really need a t/a?
Old Jun 21, 2006 | 12:02 AM
hpjunky98's Avatar
edit: actually i have no idea what your talking about. the motor itself doesn't need a torque arm.
Old Jun 22, 2006 | 11:12 AM
a-low's Avatar
I mean the car itself. How will the car handle without one?
Old Jun 22, 2006 | 12:18 PM
BADSS's Avatar
Thumbs down
I don't think that's a real good idea. Probably not safe. But I'll leave it to the suspension experts to explain why.
Old Jun 22, 2006 | 12:49 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
The torque arm prevents the rearend assembly from rotating itself to the destruction of driveshaft,u-joints,shocks,sway bar,brake lines,etc.
Old Jun 22, 2006 | 01:49 PM
Duffster's Avatar
What FirstYrLS1Z is saying without saying, because the drive shaft connects the tranny to the rear end (differential) when you hit the gas even mildly, it turns and tries to either rotate the differential up or down (directional of course) and if that happened, it could pull the drive shaft out of the tranny. . .then you would go POGO w/the car. . .pogo is bad. . .pogo gets expensive and could hurt you. . .
Old Jun 22, 2006 | 04:06 PM
Ditmeion's Avatar
I had wheel hop BAD, have not had it once since putting in my spohn torque arm...kinda pricey, but the difference was night and day with the wheel hop I had
