Adjustable lower control arm question
Does adjusting them maybe a 1/4 in longer than stock effect anything other than maybe pinion angle? I have an adj. torque arm so i reset it back at -2 if it does change.
Only reason i want to lengthen them is bc my tires sit more forward in the wheel well, and even 255/50/16 bf drag radials rub sometimes. and now that i have a set of Bf Goodrich 275/50/16(yes that's right) tires on the rear, they rub horribly.
Thanks
