LCA Relocation Bracket Question! Help!
Old Jun 22, 2006 | 06:02 PM
ShadyPhi's Avatar
Default LCA Relocation Bracket Question! Help!
I'm getting ready to buy the UMI LCA's and panhard rod. (both non-adjustable)
Also, just an FYI my car is NOT lowered, and I am not planning on lowering it.
My question is this... should I also buy the LCA relocation brackets... or is that not necessary??
Thanks!
Old Jun 22, 2006 | 07:34 PM
UAZ28SS's Avatar
Not necessary, no. Why would you NOT lower the car? Do you not care about looks or performance??
Old Jun 22, 2006 | 07:37 PM
CW00BlackTA's Avatar
Thanks!
Get the adjustable panhard rod so when you lower, you can recenter your rear. Get the brackets when you lower.
Old Jun 22, 2006 | 07:58 PM
Lethal_Ws6's Avatar
Why would you not lower you car ? you can still pull decent 60ft times on a lowered F-body..
Old Jun 22, 2006 | 08:09 PM
ShadyPhi's Avatar
Why won't I lower? I have a couple reasons
1) Clearance. The headers already hang down low enough....
2) I like performance & handling... but I'm not die hard. I've never even ran this car at the track, and I really could care less to ever do that.... just not for me.
3) I like the way it looks now... doesn't look too high at all.
4) Because I can.
Old Jun 22, 2006 | 08:41 PM
ls1muscle's Avatar
They are not just for lowered cars. LCA relocation brackets can aid in traction and eliminate wheel hop.
Old Jun 22, 2006 | 09:42 PM
bigbowski03's Avatar
If you are going to drag race the car, then yes i would get the relocation brackets for sure and set the lca's at 2 to 3 degrees uphill.
