Swaybar endlink question
When the endlinks were installed, the ES bolt was too short, so we ended up using the stock bolt and nut/washer. The stock is a smaller dia/thread.
Just wondering what everyone else did..
edit: We also had to use a jack on the rear swaybar to push it up high enough to get the aftermarket endlinks to connect.
Alan
[ December 14, 2001: Message edited by: SlowZ28 ]</p>
What I did was jack up one side of the car, and support it with a jackstand under the frame-rail. Then gently jack up the a-arm to put the bolt in reach of the swaybar. Go ahead and totally tighten that endlink up and go to work on the other side of the car. You should have a much easier time getting this endlink on now that the other one is the same length.
I didn't grease my endlinks and they are completely silent. You may want to try tightening them a bit past the factory spec of 16ft/lbs to quiet them down a little. Tighten them up til you see the poly compress a little and you know you're getting to the right area.
JOsh
