Warping Rotors?
Also, I tried the KVR's, they didn't warp, just cracked so bad that they became big expensive paper wieghts.
I am now running the $90 a pair Autozone rotors. So far, 15k miles and one Autox event no warping.
If they are disposable, may as well buy the cheap ones!
Be sure to torque lug nuts 100 lb-ft, as stated before.
These cars have 2 piston calipers with big swept area pads. They also weigh in at a svelt 3700+. That's a LOT of mass to stop.
After making a 100+ 1/4 mile pass and after sitting in the staging lanes for 30 minutes or more, the brake rotors are absolutely cold. After that pass, you stab the brakes to make the turn in. You are adding a LOT of heat in very short order, only to go sit in the staging lanes and begin the cycle again.
Tooling down the hiway at 70+mph and stab the brakes for a dumbass SUV pilot ...
I believe this is a heavy contributor to the problem.
1) Guaranteed against warpage
2) The cross-drilling was a weight-saving and looks mod, but the holes are CAST, not drilled. This eliminates the cracking risk of drilled rotors.
I've only had them for a couple of thousand miles, but they are working very very well without even a hint of warpage. My old stock rotors warped so badly when I replaced them that they literally shook off my watch band once <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
