Chrome Moly A-Arm and K-Frame
Old Mar 23, 2002 | 01:53 AM
leungken's Avatar
Default Chrome Moly A-Arm and K-Frame
I was wondering, is there any significient advantages and dis-advantages when comparing chrome-moly (4130) lower A-Arm versus mild steel ones?
I heard arguements on both sides:
Advantage: Chrome-moly units, stronger.
Dis-advantages: Tends to fatigue crack.
Any input or comments on these subjects, I am specifically looking into both the Chrome-Moly PA Lower front A-Arm and Light weight K-member for my SS.
Thanks in advance <img border="0" alt="[hail]" title="" src="graemlins/gr_hail.gif" />
<small>[ March 23, 2002, 01:54 AM: Message edited by: leungken ]</small>
Old Mar 24, 2002 | 06:32 PM
FastOrange99Z's Avatar
Default Re: Chrome Moly A-Arm and K-Frame
They are very close in weight, but if you going to drive on the street, id go with mild steel.
Old Mar 24, 2002 | 08:06 PM
BIGBOS's Avatar
How much is the mild steel?
Old Mar 24, 2002 | 09:29 PM
leungken's Avatar
70%/30% Street versus track, I guess go with mild steel.
Prices, on thunder racing web site:
Lower A-Arm, PA: $425 Mild, $495 Chrome-Moly
K Member: $439 Mild, $539 Chrome-Moly
If I am going with the mild steel one, I giess I am going to go with the G-2 setup. Thanks.
Old Mar 25, 2002 | 12:19 AM
SAINT WS6's Avatar
Chromemoly will be stronger, but it can crack on you(however, i've never personally seen it happen). If your car is driven alot, I would go with mild steel. It's only 1-2 lb. difference anyway. Plus, the mild steel will have a little more flex to it. That's what I'm doing.
Old Mar 25, 2002 | 06:58 PM
SuperCamaroSS's Avatar
go to www.ls1speed.com
Old Mar 25, 2002 | 08:39 PM
LJ_Z28's Avatar
Check out these prices...
https://ls1tech.com/ubb/cgi-bin/ulti...;f=10;t=000405
Carlos
