front end aligment
also what are the stock aligment settings.
<small>[ March 26, 2002, 02:08 PM: Message edited by: rnr27band1 ]</small>
Especially with the wide 275's.
Thanks alot,
John
For a 17" tire, keep the tire pressure around 36 psi(cold) if you drive agressively...you could also install a 1LE front sway bar to help keep the car from leaning over on the tire during hard cornering.
Since it appears you have 16" rims...that is most of the problem...the sidewall is giving under the stress and trying to roll under the rim. The new alignment will help...play with tire pressures until you find what works best.
<small>[ March 28, 2002, 02:12 PM: Message edited by: NOBR8KSS ]</small>
Can someone please post the stock alignment specs.
Thanks alot,
John
why do you care about factory specs? they're trash... but if you really want to know, just pick up a phone and call your dealership's shop
just do something like this..
-.5 to -1 degrees camber
maximum positive caster
zero toe
btw.. a shop that is more 'modern' does not mean that they own an allignmnet rack that your car will be able to drive up on... just gotta look around
<small>[ March 31, 2002, 12:19 PM: Message edited by: prockbp ]</small>
