Springs and Shocks ???
Old Apr 2, 2002 | 09:18 PM
Zero2Sixty's Avatar
Default Springs and Shocks ???
I want to lower the car, replace the stock shocks (decarb's) and increase street performance as its not all about light to light runs.
Help me out here, I have read lots of posts and there are many different options & products (street vs track etc..) so please comment on what I've chosen so far. This would be used strictly for street-use.
1. Ground-Control coil over kit with Eibach springs (spring rate based on street-use only), matched with Bilstein HD's. This is at a higher cost but with adjustability.
or simply
2. Eibach Pro-kit with the Bilstein HD's. Obviously this the lower cost alternative.
I've already ordered Relocation Brackets, Lower Control Arms, Adjustable Panhard Rod.
Thanks in advance !
2001 Z28 Monterey Maroon :
Fully Loaded, 3.23 Performance Axle, A4, Corsa Performance,
Shaner S2 Ported+Polished Throttle Body,Throttle Body Bypass, Throttle Body Bump Stop,
FRA, K&N Fuel Injection Performance Kit-2, 17x9.5 Torque Thrust II's w/ BFgoodrich G-force KDW,
BMR Shock Tower Brace, BMR Front & Rear Sway bars, BMR Boxed Subframe connectors, Baer Eradispeed Rotors,
Custom Mandrel Y-pipe (Nicks), Vigilante Torque Convertor (2800 w 2.5 str).
