Eibach Advice
Old Apr 4, 2002 | 02:34 PM
JonSS's Avatar
Default Eibach Advice
I have a 35th and am in dyer need of lowering it!
God, I feel like i'm drving a rally 4X4. I was spoiled before... I use to have Koni's on my 68 camaro. Anyway, I want to get it lowered quick, and am going with the Eibach Pro Kit, My question is... Will I be okay just replacing the springs, and not the shocks right away?? (Need to save money too so looking for an inexpensive way to lower) Also, is RK Sport the cheapest way to go for purchasing the Pro Kit? Let me know?
Unless one of you guys who are posting that your car dropped too low with the Pro Kit want to sell me yours <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Apr 4, 2002 | 06:51 PM
TOO Z MAXX's Avatar
Default Re: Eibach Advice
Do you want to lower it for performance or just for looks?
As far as buying Eibachs, try one of the sponsers of this site like Thunder Racing, thats were I got my Eibachs from. RK Sport is a little on the high side as far as price goes.
I would also change shocks while your at it, The stock shocks will not be able to control those eibachs.
Old Apr 4, 2002 | 07:14 PM
JonSS's Avatar
Lowering it just for looks.
I think i'm going to go with the H&R's from RKSport. $199 for the kit.
Old Apr 4, 2002 | 09:27 PM
prockbp's Avatar
if you're lowering your car just for looks, then there is only one way to go!
the Ground Control Adjustable set-up
buying a set of springs just won't cut it if you're only into looks... an adjustable ride height kit is exactly what you need
http://www.ground-control.com/gcapguid.htm
<small>[ April 04, 2002, 09:31 PM: Message edited by: prockbp ]</small>
Old Apr 6, 2002 | 12:27 AM
LS1pilot's Avatar
I have had Eibachs for about a year and I like them. I went with Bilstien shocks since I had her tore down and didn't want to do it again but I know of plenty of people (mostly on LS1.com) that stayed with the stock shocks. You might consider getting the front struts now as you have to get a spring compressor and go through the whole front end tear-down to get to the springs. Do you have a Helms manual? Good info on how to do it (But I guess you have experience if you had a Gen 1...!!)
A couple other things to consider since lowering throws things out of align...
Adjustable pan hard rod for the rear.
Lower control arm relocation brackets to get the control arms back to where they should be.
A full front end alignment since the lowering will throw off the camber and you will start wearing the insides of your tires.
While we're at it....get some lower control arms for the back...BMR has good prices for these mods.
I just sold my eibachs and am going with the Ground Control height adjusting system since I put on tubular A-arms in front and now the Eibachs are TOO low!!
You might check e-bay ...search under automotive parts for "Eibachs"...I hear there are good deals there...
Good Luck!!
