Need help ASAP!
Example:
DS :+1
TA:-1 OR 0
=-2 or -1
But also a lot of guy are saying that this method is wrong and you should measure the angle of the output shaft of the tranny and adjust the pinion angle from this measure.
Here is a link:
http://www.streetissuecustoms.com/pinionangle.html
Pay attention to adjust it the best that you can,because it can cause vibration/noise at high speed if the pinion angle is not adjsut correctly.
I ve tried the 2 method but i still got problem with this adjustement.
https://ls1tech.com/forums/suspension-brakes/533216-deep-noise-since-suspension-mods.html
And by the way dont ask: "anyone? seriously i cant figure this stuff out" after only 24 mins of your original post
