Car Pulls to the left while driving casually....
Old Apr 22, 2002 | 02:45 PM
SSBoy's Avatar
Default Car Pulls to the left while driving casually....
I just noticed this when i went to put my stock wheels/tires back on up on the front. (previously had the skinnies)
The car will pull to the left if i am driving down a straight road. I have verified to make sure its not the road by repeating this on many different roads.
History Of my car: was lowered with eibachs. NEVER did get an allignment with the eibachs. Put the stock springs back on with no allignment. So all in all, i have stock alignment.
What do u think could be the problem? When i took off my eibachs (like a year ago) the car steered fine. Its hard to believe that the eibachs could even cause this.
thanks for any help. The car has almost 40K miles on it. Does the allignment on most cars need adjusting at 40K miles?
Old Apr 22, 2002 | 10:40 PM
Damian's Avatar
LSX Mechanic
Default Re: Car Pulls to the left while driving casually....
More than likely you have a pull in the tires because of excessive tire wear due to not aligning after lowering. Rotate them to the back and check all the air pressure. That should fix your problem.
Josh
Old Apr 23, 2002 | 01:37 PM
SSBoy's Avatar
Damian,
my tires in the front are pretty bald and worn out. Could that have any kind of role in my problem?
