Steering with a mind of it's own
When I brake hard (Not even really a panic stop) the wheels jerk to the right and the steering wheel **** about 45* to the left.
Once this happens, the car stops on a dime straight and true, BUT now the left front tire is riding on the outside edge, and it feels like it has a ton of toe, it squeals around every left hand corner.
After a couple of bumps the car swerves a little bit and the steering goes back to normal....
OY...I was wondering if the steering rack has gone bad, but everything was fine before I took it into the shop. The problem showed up afterwards. The shop has bent over backwards trying to fix this problem, free of charge and to the point of even giving me loaners.
They don't think it's the steering rack, and I can't imagine that it could just go bad all of a sudden.
But stranger things have happened.
So:
1) Could the steering rack go bad, just like that?
2) could a shock going bad cause that problem (When I push on the corners of the car, it doesn't float, there's no clunking either)
3) Could it be a component of the steering gear.
I really can't afford the 1180 (1600 including labor) for a new steering rack and pump, etc., so if it could be something simple, I would be eternally grateful...
Thanks
I then came back to center and the steering was straight again.
It's going in for an oil change on Wednesday and I specifically asked that the bolts and mounting locations be checked out. Hopefully they wont be the stereotypical stealership and try to push a new rack on me...
. check your tie rods too.
