Question about Adjustable LCA's
Old Apr 27, 2002 | 04:36 PM
Postal's Avatar
Default Re: Question about Adjustable LCA's
Use the stock bolts. They work fine. The adjustment should be fine the way they were sent. Used a flat surface. Layed the car down and then measured each side with measuring tape. Just wanted the space between the 2 tires from left to right to be the same. Again that's just me
Old Apr 28, 2002 | 12:04 AM
Hp Joe's Avatar
Default Question about Adjustable LCA's
I Just bought adjustable lca's and I know How they go on, but ( here is where the questions come) I did not get any bolts with them. Can I use the stock ones or do you suggest getting new ones? If so what size do I need? Now I got the adjustable. But what do I adjust them too? I will be driving on the street a lot but it is mostly for track use. Thanks for your help. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Apr 28, 2002 | 06:30 PM
Hp Joe's Avatar
thank you for your help. But when they came in the mail. I played with the adjustment and they are uneven now. What do you think is the best adjustment long medium or short.Or do they judge them by exact measurement. Thank for your help.
Old Apr 29, 2002 | 06:19 PM
Hp Joe's Avatar
TTT help please What should i Adjust them to.
<img border="0" alt="[Firebird]" title="" src="graemlins/formula.gif" />
Old Apr 29, 2002 | 07:25 PM
minivette's Avatar
Take one of your stock ones off and adjust it the same as that.
Old Apr 30, 2002 | 05:42 PM
Hp Joe's Avatar
Thank you very much.
Old May 1, 2002 | 12:58 AM
Black Magic's Avatar
Stick the bolts through a stock one, and hold the new one up to it. Adjust it until the bolts are centered in the holes. Then lock them with the lock nut. Make sure both sides are the same!!! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
