Bench Bleeding Master Cylinder Question
1) I can't remember the details beyond placing the MC in a vise with brass plugs and adding fluid and pushing the piston a few times to remove the air. But once I remove the brass plugs to install the regular lines doesn't air re-enter the master cylinder off -setting the prior bleeding? Or does the fluid running out while connecting the regular brake line stop the air from re-entering so it's not a problem. Please advise and thanks in advance for your response!
Pump the MC piston and watch for the air leaving the temp lines in the container.
The lines are submerged so that when you pull the piston back, it doesn't suck air back up into the cylinder, rather it pulls fluid.
Once all the air is out, pull the piston back to the rest position which has the ports sealed off.
Then, install.
I'm just not seeing in my mind's eye how doing that way fills the MC up with fluid displacing the air. Does the compressed air leak past the inner seals?
Just curious
