bilstein hardwear question
Old May 14, 2002 | 12:38 AM
Led Foot's Avatar
Default bilstein hardwear question
i am putting on my new revalved bilstein's and have a question. A little bag came with the shocks with the shock top cap, a nut and a washer. Where does the washer go?? On the shock shaft or on top of the rubber mounting part of the upper arm that slides in the fender?
Thanks a lot,
Donny
Old May 14, 2002 | 04:47 AM
roy's Avatar
roy
Default Re: bilstein hardwear question
If this washer's outside diameter is basically the same size as the shoick rods diameter, then it goes on the rod first , then the blue dust boot.
