need advice on rotors
Old Jul 5, 2006 | 04:46 PM
99FBODY's Avatar
Default need advice on rotors
what type of rotors are people using. i have to do a brakes on my car and i want cross drilled rotors what brands would you recommend.
Old Jul 5, 2006 | 05:14 PM
Viper's Avatar
Brembo blanks; you want the most surface area possible to stop the car properly. My $.02.
Old Jul 6, 2006 | 09:27 AM
JasonWW's Avatar
If your going to pound the brakes and get them hot then blanks are the better choice. I cracked a set of crossdrilled rotors due to heat so I switched to the Autozone blanks. The $40 dollar ones (maybe called Duralast?). So far they have held up fine with my aggressive Carbotech Panther Plus pads. I also painted the centers with high temp paint and they have yet to show rust!
If your set on crossdrilled, I can't help you.
Old Jul 6, 2006 | 11:40 AM
black01_WS6's Avatar
get a set of brembo blanks, or look to some of our sponsors to the right. the brambos are the best bang for the buck.
Old Jul 6, 2006 | 12:08 PM
michaelg589's Avatar
I have Powerslot slotted rotors and they work great. There's still plenty of surface area for stopping and the slots help with heat. I was using Bendix semi-metallic pads, but they were terrible. tons of noise and dust and they got soooo hot. I'm using HAWK ceramic pads now and theyre great.
Old Jul 6, 2006 | 02:16 PM
JasonWW's Avatar
Originally Posted by black01_WS6
get a set of brembo blanks, or look to some of our sponsors to the right. the brembos are the best bang for the buck.
Actually, they're not. The Autozones are $40 and I think the Brembo blanks are around $55-$60.
Old Jul 6, 2006 | 09:54 PM
presto_z's Avatar
if you want crossdrilled and slotted i just picked some up w/ hawk pads the other week from summit and i love ummm....huge improvment in braking and look badass... i think the ws6 store has a sale going on for super cheap.....
Old Jul 6, 2006 | 10:59 PM
well I have used the autozones and the crossdrilled and slotted and have cracked both. the brembos are working very good and not having a problem, actually think that they are working better than the crossdrilled and sloted. I actually hated the autozones, **** from the get go, but maybe I just had a bad set.
Old Jul 6, 2006 | 11:11 PM
sixvi6-camaro's Avatar
Thumbs down imo.. don't get the drilled and slotted.
I drive my car daily putting 250+ miles on it a week in rain, snow, hail everything and Brembo blanks (no holes or slots) are the way to go. I did the drilled and slotted rotor thing all recomended by people on this board as being "great". Well they all warped and/or cracked within a couple months of true daily driving. Seriously just go Brembo blanks and leave the "cool" factor of the holes and slots in the rotors behind. Saftey and reliability is a lot cooler when it comes to brakes.
Old Jul 7, 2006 | 08:00 AM
JasonWW's Avatar
well I have used the autozones and the crossdrilled and slotted and have cracked both. I actually hated the autozones, **** from the get go, but maybe I just had a bad set.
Maybe you had the cheaper AutoZone blanks. The $40 ones are used by many auto-x and road racers and have held up to tremendous heat and abuse. I've heat cycled mine several times and have yet to even warp them.
Old Jul 21, 2006 | 01:38 PM
Camaro Rick's Avatar
Where does one acquire these "Brembo Blanks"? Can a good set of pads be recommended for them? Sorry for the Hijack, I'm also in the same boat...worn out warped to **** rotors...
Old Jul 21, 2006 | 02:50 PM
Viper's Avatar
www.stranoparts.com for the Brembo blanks, and Sam can recommend pads too.
Old Jul 21, 2006 | 09:17 PM
Firehawk526's Avatar
I went the zinc-plated slotted only Brembo's(no drill).......kinda best of both worlds!
Look good but don't sacrifice the integrity of the rotor itself. Slots aren't very deep, and designed for show!
All personal preference and objective driven (daily, autocross, drag, etc)
Old Jul 22, 2006 | 10:56 PM
erikthegoalie's Avatar
i 2nd that...best o both worlds!
Old Jul 22, 2006 | 11:14 PM
timberman00's Avatar
I need new rotors/pads too. My local car guru reccommended changing the flexible brake lines to the calipers to stainless steel. He said it will improve braking noticeably. Has anyone done this?
Old Jul 23, 2006 | 12:15 AM
Boodyrider's Avatar
It's a good idea for several reasons, but primarily you'll see slightly more responsive braking as the stainless lines won't swell at all, meaner quicker braking response. Also look good and last a long time. i think 'noticeably' will depend on the condition of the hoses now.
Old Jul 23, 2006 | 07:00 AM
Viper's Avatar
Noticeably no, Repeatability, yes. In other words you won't feel it stop any better with stainless lines, but if you do repeated stops ( say road racing ) you won't fade as quicky.
Old Jul 23, 2006 | 12:31 PM
2005suburban's Avatar
Another for Brembo Blanks here!!
Old Jul 23, 2006 | 05:52 PM
davered00ss's Avatar
Moderator
the WS6 store has some nice slotted/Cross drilled rotors. I believe thay are Brembo blanks.
Old Jul 23, 2006 | 06:26 PM
Viper's Avatar
Brembo 'blanks' mean they are blank, thus no holes or slots.
