Line Lock Question?
Old May 27, 2002 | 04:20 PM
ShadowZ28's Avatar
Default Line Lock Question?
I have a Moroso Line Lock that looks exactly like the SLP one. Anyway I need to know the size of the brake lines cause I gotta go to Pepboys and pick up them and bend them myself since the Line Lock only came with the solenoid, switch, light and fuse. Does anyone know the size of the lines and am I missing anything I'll need to install it? I also need to know the size of the fittings that screw into the the Master Cylinder and ABS block if anyone knows.
Thanks
Joe <img border="0" alt="[chug]" title="" src="graemlins/gr_chug.gif" />
Old May 28, 2002 | 09:14 AM
ShadowZ28's Avatar
Default Re: Line Lock Question?
TTT
Old May 28, 2002 | 09:21 AM
prockbp's Avatar
did you try posting this in the drag racing forum?
Old Jun 2, 2002 | 03:04 PM
Kevin's Avatar
Brake line is 3/16". The fitting on the abs unit is metric M.10 while the line locks are usually a standard thread. You can get around this in 2 ways. Either buy the Hurst Camaro/Firebird adaptor from Summit/Jegs for 10 bucks or reuse the factory fitting by putting a double flare on the brake line.
Kevin
