help problem w/ brakes/calipers
Old Jun 3, 2002 | 04:02 PM
Bout'ItZ28's Avatar
Default help problem w/ brakes/calipers
i just got done doing my brakes i put on the autozone rotors w/ some new dustless pads. i just took out the two 18mm bolts at the back of each front one the whole thing comes out and i change the rotors and pads. well i put everything back on and my skinnies wont fit(hitting the calipers, i do have the spacers in place). i dont know y because everything seems to be in the exact place where it came out. i have other wheels and those go on no problem and i have been driving around on those but any help would be appreciated
Andre
Old Jun 3, 2002 | 05:45 PM
prockbp's Avatar
Default Re: help problem w/ brakes/calipers
maybe your caliper mounting brackets could be loosened up and pushed towards the spindle a little
that's the only thing i can think of
Old Jun 3, 2002 | 08:35 PM
kent's Avatar
Check and see if the wheel is being squeezed against the calipers. Generally, you can tell from marks on the calipers. Are the pads thicker than previous ones which may have cause this problem. Just trying to help.
